Converting files
Alpha_Whiskey01
Converting files
Most of my music is in MP4 format and, as a result, won't play like it should normally. I need to know how to convert it back to MP3, or something of the sort, so that I can make ring tones. While in MP4 format, it loads just fine. But it plays as though its super compressed and sounds like one singular chirp, it plays so fast... Any help would be awesome... Thanks...
Re: Converting files
Audacity 1.2.x does not support MP4 files.
You could upgrade to Audacity 1.3.12 and install the optional FFMpeg :
http://audacityteam.org/download/beta_windows
http://manual.audacityteam.org/index.ph ... tallffmpeg
Alternatively, you could use a file format converter program such as the free SUPER by erightsoft.
Alpha_Whiskey01
It worked... Thanks...
