I cant Import Wav files into Audacity
Ok. for some reason, now, this was working fine earlier today, but now, when i try to import files, or even open the audacity project files, and yes, i am going through File, and such like, it'll just tell me, it either cant find it, if im trying to open, or it cant find the specified path.. and i have no idea why.. they are saved in the default place.. and i cant see any reason its doing this.. and i can tell you.. its realy frikkin anoying.. anyone who has a fix for this.. that'd be awesome.. >//<
Re: I cant Import Wav files into Audacity
uhm.. well.. that was undeniably random.. problem fixed.. itself.. somehow.. xD
If you start experiencing an unstable Audacity 1.2, stop using it. Download Audacity 1.3.12 from here...
...and use that. You can install both Audacity versions, but only use one at a time. Audacity 1.2 Projects should open up in 1.3.12.
