"What you hear" and stereo recording?
Since there's no free audio converters that I can find that will convert MP4(Apple iTunes propietary format...or are there?) to MP3 I'm trying to re-record 2 iTunes songs I purchased into Audacity so I can play it as an Mp3. I'm using "What you hear" as the source but it seems I can only use a mono track. I'd like to record to stereo....how can I do this?
Dual 1.4 processor G4 w. 1.25GB RAM
Tiger 10.4.11
Pro Tools LE 7.3, Audacity 1.2.6 stable, MuLab Free
Live Lite 6, Reason Adapted 3.0
hp Media center pc 873n Intel Pentium 4, 2.53.GHz.
Audacity 1.2 stable
Nec Asperra Terrent
Tiger 10.4.11
Audacity 1.2 stable
Nec Asperra Terrent
Re: "What you hear" and stereo recording?
To record a stereo track you need to set stereo recording in preferences:
"Edit > Preferences > Audio I/O" "Channels = 2 (stereo)"
I don't use iTunes myself, but from what I've heard, I thought that you could convert from MP4 to MP3 in iTunes.
waxcylinder
Indeed you can - but I think it keeps the DRM on the MP3stevethefiddle wrote: I don't use iTunes myself, but from what I've heard, I thought that you could convert from MP4 to MP3 in iTunes.
One way to do it would be to create a playlist - burn a CD - then rip the CD to MP3 (this is the "classical" way of removing DRM)
Thanks guys! I've found the right setting in the prefs. I thought I had to get a track on the timeline before I recorded...like other DAWS. I rarely use Audacity for recording...mostly editing.
Tiger 10.4.11
Audacity 1.2 stable
Nec Asperra Terrent
Tiger 10.4.11
Audacity 1.2 stable
Nec Asperra Terrent
