CRASH when using Effects
wavdav
Post by wavdav » Fri Nov 12, 2010 10:13 pm
hey, i used audacity for a couple years and havent had this problem before... now when i try to use any effects(amplify,change pitch etc) the program is closing most of the time.
...any help? thanks
ps. cool place here !
Re: CRASH when using Effects
Post by steve » Sat Nov 13, 2010 2:31 am
Are you trying to use Audacity 1.2.6 on Vista or Win 7?
wavdav
Post by wavdav » Sat Nov 13, 2010 10:53 pm
1.2.3 on XP
Post by kozikowski » Sun Nov 14, 2010 12:24 am
Does it still work on any of the older shows? If you pull down the six second piano solo from here...
http://www.kozco.com/tech/piano2.wav
...and play it in a fresh Audacity, is it still unstable?
You can also get ratty operation if you added new filters or plugins. Did you? Can you temporarily pull them out of the plugins folder and see if it's better?
You don't fall into the perfect candidate for a software upgrade, but you're close. Download and install Audacity 1.3.12 from here...
You can have both versions on your machine, but only use one at a time. Audacity 1.3 projects will not open in 1.2.
Audacity 1.2, especially 1.2.3 is very old and no longer supported, updated or patched. If it becomes unstable, blow it away. You can still get Audacity 1.2.6 if you decide you just can't live with the newer version.
Post by kozikowski » Sun Nov 14, 2010 12:26 am
Since you have a "mature" machine, how full is your hard drive? Audacity will not run into a full or fragmented hard drive.
wavdav
Post by wavdav » Mon Nov 15, 2010 10:14 pm
Well i played that piano clip in Audacity 1.2.3, used the same effects and couldn't get the program to shut down so... ?
There are no plugins or filters added that i know of.
If i downloaded the new Audacity could i transfer over my old projects ?
Post by kozikowski » Mon Nov 15, 2010 10:25 pm
It is intended that all the old Audacity 1.2 projects open in Audacity 1.3.12. In any event, you can have both versions installed, just don't try to use both at once.
If you have "magic" sound files, it's possible both versions will be unstable.
What kind of shows are you trying to edit?
Post by kozikowski » Mon Nov 15, 2010 10:29 pm
You can get your symptoms with memory errors. Audacity might be the only application you have that tries to use all the machine memory it can get. It's not unusual for a bad memory stick in high memory to go unnoticed for a long time -- until you try to do effects on a large Audacity show.
Microsoft makes a very nice memory tester.
http://oca.microsoft.com/en/windiag.asp
Run it multiple times. Sometimes memory errors don't show until two or three passes.
wavdav
Post by wavdav » Thu Nov 18, 2010 9:04 pm
I went ahead and downloaded the new Audacity 1.3.12, opened a project that i had done on 1.2.3 and there was NOTHING in the audio tracks.. just flat line. So i closed 1.3.12, went back to 1.2.3 and the project wouldn't open so.... i guess i lost the project?
