lame file to work audacity not opening
have downloaded it heaps but when try open it,computer says ???????,cannot open is there attachment file somewhere fix this??
Re: lame file to work audacity not opening
My recommendation would be to upgrade Audacity to version 1.3.12 which you can get from here: http://audacityteam.org/download/
then follow the instructions for installing Lame here: http://audacityteam.org/help/faq?s=install&i=lame-mp3
If you still have problems, please describe exactly which step you get stuck on and what if an error messages you get.
