not able to record using microphone
GBS
Post by GBS » Fri Nov 05, 2010 3:40 pm
i have recently bought the Tascam TRACKPacKX1 Recording system. i am trying to record using my computer, which has windows vista and audacity. but no output is coming. i can however listen output when ever i record without microphone. can u please help me how to use microphone into the system. Thanks a lot.
Re: not able to record using microphone
Post by steve » Fri Nov 05, 2010 5:17 pm
It is highly recommended that you upgrade to Audacity 1.3.12
http://audacityteam.org/download/beta_windows
In Audacity 1.3.12:
Edit menu > Preferences > Devices
check that your USB device is selected as the recording device.
check that the sound card that you are using for playback is selected as the playback device.
GBS
Post by GBS » Fri Nov 05, 2010 6:29 pm
thanks a lot. Steve. Although I am sure the settings are correct but I havent still tried on the newer version of Audacity.. will try tonite and hope to get thru the trouble.. thanks once again..GBS
GBS
Post by GBS » Sat Nov 06, 2010 8:32 pm
hi .. i have upgraded my audacity version..but still its same..not able to record using microphone.. can some one help me make a diagnosis of wats going on?
Post by kozikowski » Sun Nov 07, 2010 4:23 am
That was painful. The web site has no good pictures so I had to download the instruction book.
Do you have the USB light on the front of the US-100? Do you have the little switch on the back set for "Mic?" Advance the left knob "Input" until the green "SIG" light on the left of the US-100 flickers.
Go into Windows Control Panels and select the US-100 for recording. Follow the instructions on Page 14.
After all that, launch Audacity and set Edit > Preferences > Recording, so it's looking at the same thing as the Windows Control Panel.
I would probably start with Audacity sound settings of 44100, 16-bit, Stereo. You can get fancy later. Restart Audacity if you change any of these settings. Press Record in Audacity and watch for the bouncing red sound meters and the creation of the blue waves. Forget listening for a minute. First things first.
GBS
Post by GBS » Sun Nov 07, 2010 3:02 pm
Dear Kozi,
Thanks a lot for so much of of effort for helping me out. I was finally able to make it.. after many attmpts.. which required "sync"ing of all the components of the system.
Regards,
GBS
