exporting file
exporting file
Each time I try to export a particular multiple file as Wav., I get the message, 'Cannot export files to C/Documents... etc'. I've successfully exported these files as a single 46 minute file in the past, so am I doing something wrong? I go through every Export Wav. step carefully but still get the failure message. I've exported other files in the past without trouble.
waxcylinder
Re: exporting file
I suspect that you are using special characters like / in your filename(s).
I usually make fairly vanilla filenames in Audacity labels and then edit the filenames and metadat tags later, after export.
