Importation error?
Kitty.x
Importation error?
Post by Kitty.x » Wed Nov 03, 2010 8:58 pm
I have imported an mp3 track into audacity and oddly enough when I play it, it sounds like communication with an alien or something! At first, I thought Audacity had sped it up, turns out this isnt the case, it's genuinely importing utter distorted rubbish... what do I do? I've tried dragging and dropping and importing via the protect drop down menu, help!
~Thanks
Re: Importation error?
Post by steve » Wed Nov 03, 2010 11:18 pm
You are trying to import a file type that is not supported.
If you upgrade to Audacity 1.3.12 and install FFMpeg many more file types are supported.
Here's the links:
http://audacityteam.org/download/beta_windows
http://manual.audacityteam.org/index.ph ... tallffmpeg
