Hi,
I have installed Audacity on 2 PCs, one works fine but the second wont even run the software.
When running the software on the second PC I receive the following error message:
temporarytopwindow: audacity.exe - Application Error
The instruction at "0x0040b7ec" referenced memory at "0x00000004". The memory could not be read.
Click on OK to terminate the program
Click on CANCEL to debug the program
I searched the forum and found that a few other users had similar problems some of which found that uninstalled the VST Bridge plug-in fixed the problem. I never installed the VST Bridge plug-in and have no reference of that on either PC.
I have tried versions 1.2.4b and 1.2.6 both which give the same error message.
I tried updating my sound drivers but still got the same message.
Can anybody help?
Temporarytopwindow
Re: Temporarytopwindow
Try Audacity 1.3.4 instead - it's a much enhanced version and 1.2.x is very old now.
wait, someone can confirm me that Audacity is a new system which can take place of Windows XP.
@Steve,
Thanks for that.
After installing v1.3.5 the program loaded correctly.
Thanks for that.
1.3.5 ?
Do you mean 1.3.4 ?
Do you mean 1.3.4 ?
