If I (on XP SP2) click the Help Table of Contents' link http://audacityteam.org/help/documentation, I get:
Audacity Error
Unable to open requested HTML document: http://audacityteam.org/help/documentation
Do others get this too?
Help link failure
Re: Help link failure
Yes. The help file is no longer included with the default installation, however you can get it here: http://audacityteam.org/help/documentationchrisjj wrote:Do others get this too?
Well, it (audacity-1.2-help.htb) is included in audacity-win-1.2.6.exe and is, I think, the source of the line with the fault I reported.stevethefiddle wrote:The help file is no longer included with the default installation
Rats - sorry, done it again - getting confused between 1.2 and 1.3
Anyway, you can still get the manual using the link I provided (I doubt that you will often refer to it once you've been using Audacity for a bit).
