How do I get USB mic working with Realtek?
beinspired88
Post by beinspired88 » Tue Oct 26, 2010 8:29 am
Hi
I have a problem with my USB condenser microphone (Samson G track) won't work with stereo mix on window vista.
Previously, I recorded my voice from computer microphone along with the backing track instrumental music via stereo mix and it worked fine.
I just have new G track, I intent to do what I did with the better microphone. I can't get G track work with stereo mix.
Is there any way for me to use my USB mic and Stereo Mix at the same time? or does Audacity allow me to record my voice from G track with the backing track from my computer at the same time? Please anyone help me?.....
Thank you
Re: How do I get USB mic working with Realtek?
Post by steve » Tue Oct 26, 2010 1:17 pm
USB microphones completely bypass the internal sound card - this is one of the main reasons that they can give better recording quality.
beinspired88 wrote:Is there any way for me to use my USB mic and Stereo Mix at the same time?
No.
beinspired88 wrote:does Audacity allow me to record my voice from G track with the backing track from my computer at the same time?
Yes.
I would highly recommend that you use Audacity 1.3.12. If you are using an older version you should update to 1.3.12 (for version number see Audacity "Help > About Audacity")
Import the backing track into Audacity (File menu > Import > Audio)
Then record the vocals over the top.
Most steps in the procedure are covered in this tutorial: http://wiki.audacityteam.org/wiki/Creat ... h_Audacity
beinspired88
Post by beinspired88 » Wed Oct 27, 2010 6:30 am
Thank you very much for your response. Now I know what happen.
No.
Yes.
I tried it what you suggested, it seemed to work but my voice is delayed to the backing track for some reason after I recorded it I don't know why. Maybe my setting is not good. I have to play more with it.
anyway, Thank you very much
Post by steve » Wed Oct 27, 2010 12:07 pm
beinspired88 wrote:it seemed to work but my voice is delayed to the backing track for some reason after I recorded it I don't know why.
You can adjust the position of the new track using the "Time Shift" tool. Look for a button with a double headed arrow (<->) or press the F5 key. You will then be able to drag a track left/right so that they line up correctly.
Doing this will become quite tedious, but fortunately it can be done automatically (in Audacity 1.3.12) by setting up "Latency Correction". See here for more details: http://manual.audacityteam.org/index.ph ... tency_Test
