Recording Audio from Streamed Radio
MotoXMan1390
Post by MotoXMan1390 » Sat May 03, 2008 9:19 pm
Hey-
I listen to Radio every morning where I stream it every morning. However, I have to leave at 7:30 every morning and miss like 3 hours of the show. I found your program, but so far all I've been able to capture is through my microphone that picks up through my speakers. Is there a way that I could record straight from my Firefox that is streaming the radio station cause I don't want to have my speakers blaring all day (I have a bad Mic). Also is there any timer system on the program?
Re: Recording Audio from Streamed Radio
Post by kozikowski » Sun May 04, 2008 9:53 pm
Let's take the serious one first.
No timer.
Check out Audacity 1.3.
MotoXMan1390
Post by MotoXMan1390 » Mon May 05, 2008 4:23 am
k i got 1.3 (where i catually did find a timer), but the option for the streamed radio isnt there and the control panel method didnt work on mine what do i need to do?
Post by kozikowski » Mon May 05, 2008 5:37 am
You're not going to find a "Record Streaming Audio" setting. You need to go into the Windows Control Panels and find the hidden "Mix Out" or something like that.
I'm going by third hand info. You go to the Windows sound record section and find that it's missing one or two settings. Then right click in the panel and select something like obsolete or unused or hidden settings and Mix Out is in there. This is extremely fuzzy since I've never done this.
That plus the stuff here...
MotoXMan1390
Post by MotoXMan1390 » Tue May 06, 2008 2:54 am
ya i did that i didnt mean i was looking for a button i meant the options in the dropdown menu it only shows mic and line in and the control panel method didnt work but ill try it again
Post by kozikowski » Tue May 06, 2008 6:14 am
Right clicking on the control panel is supposed to open up other options.
