audacity Issues playing sound on Win 7
Brigster18
Post by Brigster18 » Thu Oct 21, 2010 4:48 pm
i load audacity and generate a tone. i then play this tone then stop it after i stop it. i then get a really high pitch interferance noise.
Any ideas on how i can fix this?
is this a WIN 7 BUG? :D
Re: audacity Issues playing sound on Win 7
Post by steve » Thu Oct 21, 2010 5:04 pm
For Windows 7 you should be using Audacity 1.3.12
Brigster18
Post by Brigster18 » Thu Oct 21, 2010 5:12 pm
I am using that version
Post by kozikowski » Thu Oct 21, 2010 5:50 pm
You posted in the Audacity 1.2 forum.
If you like capturing music from the internet, then you may have the sound system set up to capture "What You Hear, Mix-Out or Stereo Mix." All these will interfere with your local sound production.
Go into the Windows Control Panel and make sure you're set to record from internal microphone, Line-In or some other hard device location.
Go into Edit > Preferences > Recording and make sure nothing is selected. Restart Audacity if you have to change a setting.
