it used to record but not now?
wingnut
Post by wingnut » Thu May 01, 2008 7:41 pm
I am running vista and recently had to have the hard drive repalced. I haver been reinstalling my software and just installed audacity. I have used it for some time now, and had used it on this machine prior to the crash. Now it is not recording?
I have read several posts looking for an answer and have done following as a result of reading the posts.
1. I updated the driver, and it said it was uptodate.
2. Went to the realtek website and manually downloded and installed the latest driver.
In the edit menu under preferences all that is lists as inputs is front mike and sound mapper. It sure seems like there was another option there before.
Any ideas or help?
Brent
Re: it used to record but not now?
Post by steve » Fri May 02, 2008 4:46 pm
Try using "Sound Mapper" and select your recording input using the Windows Mixer.
wingnut
Post by wingnut » Fri May 02, 2008 9:02 pm
I have selected the mapper, but there is nothing to select from in the mixer toolbar.
Post by steve » Sat May 03, 2008 1:42 am
wingnut wrote:I have selected the mapper, but there is nothing to select from in the mixer toolbar.
stevethefiddle wrote:Try using "Sound Mapper" and select your recording input using the Windows Mixer.
There should be an icon in the sys tray near the clock in th ebottom right corner of your screen.
wingnut
Post by wingnut » Sat May 03, 2008 12:20 pm
I am using the sound mapper and have looked bot on the mixer toolbar in audacity and the windows mixer.
the windows mixer does not list any recording inputs. it lists
devices ---speakers
applications ------ windows sounds
I know that before the Hard Drive crash, when I had audacity working, there was something that had the be "clicked" somewhere but I dont remember where.
Post by steve » Sat May 03, 2008 3:09 pm
I don't have Vista, so I'm not sure exactly how you get at the Windows mixer settings but I thought that there would have been a "Tab" for the recording settings. Perhaps the "Vista" section on this page may help: http://audacityteam.org/wiki/index.php? ... bar_Issues
wingnut
Post by wingnut » Sat May 03, 2008 9:37 pm
Here we have the problem fixed.
I went to control panel, sound, then right clicked mouse then selected "show disabled devices". enabled stereo mix.
audacity ....went to edit, preferences then had the option of selecting the newly enabled device.
I knew it was just a few clicks away..........just needed to know which click to make.
thanks
Post by steve » Mon May 05, 2008 1:04 pm
Glad you got it sorted, and thanks for posting how you did it - this will hopefully help other people who have this problem.
