recording problem with 2 channels
mitsurugi67
Please someone help me with this problem i have. The first thing i do is record my first channel, (guitar chord or something), then i want to record a second channel ( guitar solo ), but when i record the second time, he also records the first time agian.But i just want to hear the 1st channel playing when i am recording my 2nd channel
please help me
thanks.
please help me
thanks.
Re: recording problem with 2 channels
You need to set your sound card to record directly from the input that you are using. You probably have it set to record from "Stereo Mix" (sometimes called "Mix" or "What U Hear"). Change it to record from the Line, or Mic input (depending on which you are using.
There is usually a loudspeaker icon near the time/date on your Desktop - that's where you can access the sound card settings.
If there is no loudspeaker icon, you will need to go into the Sounds settings in the Windows Control Panel to make the new settings.
Also, it is highly recommended that you upgrade to Audacity 1.3.12
I don't think there is an actual tutorial on this, but a common mistake is to record Stereo-Mix or Mix-Out instead of your microphone or sound mixer. This is the setting you need to capture internet audio or shows, but it's exactly the wrong setting for live performances into a microphone.
Go into Windows Control Panels and make sure you're set to record from the right thing.
This is the tutorial for recording Internet Audio. These are exactly the settings you don't want.
http://wiki.audacityteam.org/wiki/Recor ... e_computer
mitsurugi67
when i go to Sounds and Audio devices, and then sound recording, he only sees : 'Realtek AC97 Audio and not the line in from my amp. And i also cant select line in in the volume control . ??
You need to select "Line in" in the sound card mixer (look for a loudspeaker icon near the Time/Date on your Desktop), or if you cannot access the sound card settings there, go to the Windows Control Panel (as suggested by Koz) and set the sound card to use Line in.mitsurugi67 wrote:when i go to Sounds and Audio devices, and then sound recording, he only sees : 'Realtek AC97 Audio and not the line in from my amp.
Re: stereo recording problem
Hello,, can you help me? I have a problem of stereo recording. i see stereo input signal but the recording is mono ( only one channel). I use pc and the setting on edit/preferences/audio I/O/ is 2 channels (stereo) and the setting of recording device is usb audio codec.
tank you very much for help me
Aleo
Aleo
<<<i see stereo input signal>>>
How do you see stereo? What tells you that you have a stereo show?
If you have a USB microphone (you didn't say) then the sound from them is almost always mono no matter how you have Audacity set. Some computers allow you to force that single sound onto both left and right. If yours won't do that, then you may need to make stereo in Audacity.
When you finish capturing, do you have a stereo show with blue waves only on Left?
mitsurugi67
yeah, i know but i cant select it, thats the problem.When i click on it , nothings seems to happen. There comes no mark or something. ???stevethefiddle wrote:You need to select "Line in" in the sound card mixer (look for a loudspeaker icon near the Time/Date on your Desktop)
Could you post a screenshot of what you are seeing on the mixer.mitsurugi67 wrote: yeah, i know but i cant select it, thats the problem.When i click on it , nothings seems to happen. There comes no mark or something. ???
Use "Upload Attachment" below the forum "Compose Message" window to upload the image.
mitsurugi67
hmm, i tried to upload the prinscreen shot, but it sais : The extension bmp is not allowed. ??stevethefiddle wrote:Could you post a screenshot of what you are seeing on the mixer.
