I suspect it might be the exact mix of windows I have, or a registry entry.
After the crash, I installed the disk when it came, and installed win2K on it from the issue disks.
Then updated to SP4 and the latest fixes from MS.
Then I switched the swap file to D: and restored the backup over the top of the installed windows. I expected a few complaints, but I got remarkably few failures.
At which point I discovered that the backup software did not include any .exe, .dll, .com or .zip files.
I had my data, and the backup of my registry, but no programs and I was missing all install files. I cannot tell you if I restored the registry on not. It was on the original plan that I had to abandon because of missing files in the backup.
So I have started on the long, tedious process of downloading and reinstalling the programs, which is when I discovered the problem with Audacity rebooting as it is loading.
The only other hint of a problem is that one of the security updates will not install.
Regards
Ian
