Multiple export makes extra wav files
cprobert
Post by cprobert » Thu Apr 17, 2008 6:21 pm
Version 1.2.6, Windows XP. I have one track with 12 track labels. I did multiple export to wav files. It created a total of 20 files instead of 20. The extra files are all 1kb and are actual pieces of music. I have checked my labels, I definitely only have 12. Any ideas?
cprobert
Re: Multiple export makes extra wav files
Post by cprobert » Sat Apr 19, 2008 2:23 am
I found the problem myself. I had created track labels using silence feature, then while I was editing their names I accidentally added a new track label. Ony one track label shows even when you zoom in, until you delete the one in front.
