I have used audacity 1.2.6 for a long time to record fun little songs, nothing too serious. I have used either a mic placed next to my (guitar) amp or a direct input from my amplifiers output, to the input on the computer. This was on my HP pavilion a1160n Desktop.
However, recently I bought a toshiba satellite l505d laptop (Windows 7 64-bit, 4gb RAM, AMD Turion II Dual-Core Mobile M500 2.20 GHz). It uses realtek HD drivers/soundcard (I havent found much info on what kind of card it exactly is, but thats what i have, yes i have looked.) And when i downloaded and installed Audacity 1.2.6, I noticed a strange effect on my recordings when i recorded using the same equipment and programs as i did on the desktop i had used previously. Here's an example:
http://www.megaupload.com/?d=Y3JT8TF7
As i go to lower notes/frequencies the volume goes down, and a strange phaser/flanger effect happens, something i cannot describe. This happens with both the mic and the direct hookup from the amp to the computer.
There is nothing wrong with the amp, or the wires running to the computer, so i'm guessing there is something wrong with audacity or the sound card?
ANY help would be greatly appreciated, thank you.
