Monitoring while recording new track with mic
mountaindude
Post by mountaindude » Mon Sep 13, 2010 6:08 am
Hello,
I record through a Shure SM58 mic with a X2U USB connector. The file will not playback audibly, unless the USB is unplugged. My OS is Windows Vista.
I would like to be able to record a new vocal track over my existing guitar track, while monitoring through headphones, but all I get is silence when the USB is plugged in. I, of course, have "play other tracks..." checked while doing this.
Any suggestions?
Thanks,
Doug
Re: Monitoring while recording new track with mic
Post by steve » Mon Sep 13, 2010 4:31 pm
I'd suggest upgrading to Audacity 1.3.12, then in "Edit menu > Preferences > Devices" set the playback device to your sound card.
mountaindude
Post by mountaindude » Mon Sep 13, 2010 7:35 pm
Well, that was embarrassingly easy. There was no need to upgrade, and all it took was the change to playback devices, under "preferences."
Thanks for the advice.
Post by steve » Mon Sep 13, 2010 10:00 pm
I'm glad you've got it working, though I'd still highly recommend upgrading - if you just want to try it but keep the 1.2.6 version than you can have both versions installed at the same time. The limitations are that Audacity 1.2.6 cannot open projects that are save by Audacity 1.3.12. Also, you cannot run them both simultaneously.
Audacity 1.3.12 has quite a few really useful new features and is usually more stable than the old 1.2.6 version. 1.2.6 is really old now, is no longer maintained, and has some known bugs that will not be fixed.
