Is there such a thing as increaseing treble
shinnen
Operating System: Windows XP
Post by shinnen » Thu Apr 10, 2008 12:06 am
Hi,
I see BassBoost, but there a way of reducing bass?
.... john
Re: Is there such a thing as increaseing treble
Post by steve » Thu Apr 10, 2008 10:24 am
You can use the "Equalisation" effect.
shinnen
Post by shinnen » Thu Apr 10, 2008 10:10 pm
Hi Steve,
Thanks for the suggestion. I tried it but it didn't seem to have any effect, probably because I don't know what setttings to start with. Can you make a recommendation?
Thanks,
John
greenie
Post by greenie » Fri Apr 11, 2008 2:23 am
well lower frequencies are bass, higher is treble. 440 hz is near the bottom end of what a standard guitar can play, and about 260 hz is middle c which is halfway on a keyboard and considered near the top of the bass vocal range. So hopefully this gives u some bearing of where on the equalizer what will effect what sound you hear.
shinnen
Post by shinnen » Fri Apr 11, 2008 6:29 pm
Hi Greenie,
Thanks. That should help.
..... john
