Audacity Frozen
hoodmobsta88
Audacity Frozen
Post by hoodmobsta88 » Fri Sep 10, 2010 10:51 pm
my audacity is frozen, but i still have the screen up wit my recording... i cant play it, stop it, or save... any help?
Re: Audacity Frozen
Post by kozikowski » Fri Sep 10, 2010 11:03 pm
Is the computer frozen? How are you posting to the forum?
hoodmobsta88
Re: Audacity Frozen
Post by hoodmobsta88 » Fri Sep 10, 2010 11:07 pm
no, my laptop is ok... audacity program, is frozen, but my file is still up... i didnt exit out
Re: Audacity Frozen
Post by steve » Fri Sep 10, 2010 11:50 pm
I'm guessing that:
you are using Audacity 1.2.6
on Windows Vista and
this is a really important never to be repeated performance
that you have recorded with a microphone
on a laptop
using the on-board sound card in the laptop,
and the project has not yet been saved.
If that's correct, do a search for " *.au " (without quotes) - you will need to enable searching for hidden files.
You should find a Temp folder with loads of .au files in it.
Locate that file on the hard drive and make a copy of the entire contents.
Force Audacity to quit using the Task Manager.
Restart Audacity - if you are really lucky the project will be recovered automatically.
If anything is different from this assumed scenario, please fill in the blanks.
