E-MU 0404 USB
merlot
E-MU 0404 USB
Post by merlot » Mon Sep 06, 2010 8:06 pm
I am trying to use Audacity 1.2.6 with my E-MU 0404 USB. The internal sound card is disabled. The E-MU works fine with Acoustica Premium 4. The Audacity inputouput is set to the E-MU. The sampling rate is the same. I get the following error "Error when opening the sound device. Please check input device settings and the project sample rate."
Any help would be appreciated. I'm using windows 7.
Thanks.
Re: E-MU 0404 USB
Post by steve » Mon Sep 06, 2010 11:45 pm
On Windows 7 you need to use Audacity 1.3.12
merlot
Re: E-MU 0404 USB
Post by merlot » Wed Sep 08, 2010 1:49 am
Just installed the new version (1.3.12). I still get the same error... Any other ideas?
Appreciate any help...
Thanks...
Re: E-MU 0404 USB
Post by kozikowski » Wed Sep 08, 2010 4:43 am
A good ground zero is to set everything -- Audacity Preferences and the device -- to 44100, 16-bit, Stereo. Restart Audacity. See if that doesn't help.
Re: E-MU 0404 USB
Post by steve » Wed Sep 08, 2010 11:28 pm
merlot wrote:I am trying to use Audacity 1.2.6 with my E-MU 0404 USB.
Does Windows Media player work with the E-MU?
Does "Sound Recorder" work with it?
merlot
Re: E-MU 0404 USB
Post by merlot » Sat Sep 11, 2010 9:56 pm
Just tried at 44.1k. It works. But not 96k or 192k...
Any ideas?
Thanks!
Re: E-MU 0404 USB
Post by steve » Sun Sep 12, 2010 4:17 pm
It appears that the Windows drivers only support 44100 Hz.
It is unfortunately not uncommon that full functionality is only available using ASIO drivers (which are not supported in the standard version of Audacity) and that the normal Windows (WDM) drivers (which Audacity uses) only provide basic functionality.
In the ReadMe file for the EMU 040 USB it says:
ASIO MULTIMEDIA AT 96 KHZ AND 192 KHZ
When operating at 96 kHz and 192 kHz, we recommend you DO NOT USE WDM drivers only use the E-MU
ASIO driver in ASIO compliant programs.
http://www.emu.com/support/files/downlo ... Platform=1
merlot
Re: E-MU 0404 USB
Post by merlot » Sun Sep 12, 2010 4:38 pm
Stevethefiddle,
Thank-you for your help.... I have the E-MU ASIO drivers. But am not sure how to get them to work with Audacity. Any help in that regard would be most appreciated....
Thanks....
Re: E-MU 0404 USB
Post by kozikowski » Sun Sep 12, 2010 4:57 pm
<<<am not sure how to get them to work with Audacity.>>>
You have to compile Audacity -- build the program -- from the original written programming language -- the source code -- and include ASIO modules.
http://audacityteam.org/download/source
-- Dependencies
The wxWidgets library is required. Audacity 1.2 needs
wxGTK 2.4, compiled without the unicode options.
The next Stable version of Audacity will support
newer wxWidgets and GTK libraries.
-- Installation of the following libraries is optional - they
are included in Audacity obtained from SVN.
* libmad
* libsndfile
* Ogg Vorbis
Probably not for the casual user. The problem is that, although ASIO material is free, it's only free for one (1) user. Once you produce Audacity with ASIO support, it can only be used by you.
Re: E-MU 0404 USB
Post by steve » Sun Sep 12, 2010 5:11 pm
kozikowski wrote:Once you produce Audacity with ASIO support, it can only be used by you.
The term is "non distributable", which I would take to mean that you may not give it to anyone else.
