importing WMA files to audacity
I am ready
Post by I am ready » Sat Apr 05, 2008 8:56 pm
I am not able to import WMA files. a 60 minute talk it comes in as a 30 sec white noise.
i also can't seem to import wav files either. Yes i also tried the import raw data. result was the same.
any suggestions?
Re: importing WMA files to audacity
Post by steve » Sat Apr 05, 2008 10:22 pm
Microsoft PCM WAV files should import perfectly, but WMA is not supported so you would need to use a standalone converter such as SUPER to convert WMA files to WAV.
I am ready
Post by I am ready » Thu Apr 10, 2008 10:15 pm
thanks.
it worked.
I am Ready
carlyon
Post by carlyon » Fri Apr 11, 2008 11:57 pm
How did you do that? I am importing a .wma track, which does not work. How did you convert it to WAV?
Carlyon
Post by steve » Sat Apr 12, 2008 10:56 am
On Windows, I would use SUPER, but there are several other free format converters.
http://www.erightsoft.com/SUPER.html
carlyon
Post by carlyon » Tue Apr 15, 2008 12:05 am
Thanks, I have converted the file to WAV, but still cannot play it. Can you tell me why?
Post by steve » Tue Apr 15, 2008 3:25 am
Does it play in anything? Windows Media Player? WinAmp? Foobar2000?
If you right click on the file, select "Properties", go to the "Summary" tab and select "Advanced", what does it say? (please copy and post everything that it says, or post a screen shot).
carlyon
Post by carlyon » Tue Apr 15, 2008 9:06 pm
This track plays in Windows Media Player, where I have imported it into Audacity. It also plays in Super. When I right click on the file in Audacity nothing happens. When I right click on the file in Windows Media Player I do not get the Summary and Advanced options.
Post by steve » Wed Apr 16, 2008 3:05 pm
Let's try to narrow this down a bit carlyon - Does Audacity work OK on your computer? Can you play anything in Audacity?
carlyon
Post by carlyon » Wed Apr 16, 2008 11:43 pm
Yes, following my original enquiry about the play button, I was given a test piece to play, and it worked fine. I couldn't right click on it , though.
carlyon
