cassette is to loud
cassette is to loud
When I try to record a cassette it is to loud. Even with input at "0." I connect my cassette player to the newmark turntable I use. It reords but is to loud. Grey
- Quality Assurance
Re: cassette is to loud
Try connecting from headphones out of the tape deck, then turn its volume control knob down. If the Audacity input slider does not control the level, then also try turning down the level using the slider in the Windows Control Panel (Sound, Sounds and Audio Devices or similar).Grey wrote:When I try to record a cassette it is to loud. Even with input at "0." I connect my cassette player to the newmark turntable I use. It reords but is to loud. Grey
