multiple .wav File Import question
FatStratCat
Post by FatStratCat » Sat Aug 21, 2010 9:53 pm
I have a digital recorder that exports each recorded track via USB as a single wav file.
I now want to take all 8 .wav files and import them into Audacity as a single synchronized song so I can fine tune each track before burning it to CD.
Is this possible and if so how do I do it?
I tried to use open but it only opened up 8 separate files, and I am new at this so I'd rather find out if I can before I spend hours finding out I can't.
Thanks!
EDIT:
I figured this out. simple drag and drop after opening up the first track and it all synchs up.
waxcylinder
Re: multiple .wav File Import question
Post by waxcylinder » Sun Aug 22, 2010 10:52 am
the other way is to use Import rather than Open.
Open a new project (or open the first wav file) and then Import the other WAV files.
