Unable to record using XPPro
Re: Unable to record using XPPro
Post by steve » Tue Apr 15, 2008 4:55 am
You're quite right - we have no idea who's on the other end of the question :D
Don't forget to try selecting "wave" as the recording input - I've heard some reports that some Realtek devices treat this the same as the "Mix" recording source.
paulkinzelman
Post by paulkinzelman » Tue Apr 15, 2008 4:10 pm
When you say "selecting WAV input", I assume you mean Audacity | Edit | Preferences | Input? I see no WAV input I can select.
When I pull down input device, my options are:
MME: Microsoft Sound Mapper
MME: Realtek HD Audio Input
And I have checked:
-Play other tracks while recording new one
-Software Playthrough. Play new track while recording it.
Still nothing on the input.
I tried running a patch cable from line out to line in (but when I do that I can't listen because I'm using the single patch cord). The driver detects that I plugged something in and asks me to verify that I plugged something into 'input in'. I say OK.
But when I record with Audacity, when I have it set to the 2nd input (Realtek) I get garbage when I listen to what Audacity recorded when something is playing.
When I set it to the 1st (M$ Sount Mapper), I get some weird echo effect, completely unusable.
As you might surmise, I was a low level device driver writer, but for networks, not for sound. :-)
Any other suggestions?
Post by steve » Wed Apr 16, 2008 1:10 pm
paulkinzelman wrote:When you say "selecting WAV input", I assume you mean Audacity | Edit | Preferences | Input?
No, I mean in the Realtek mixer/control panel. Set Audacity to "MME: Realtek HD Audio Input".
paulkinzelman wrote:When I set it to the 1st (M$ Sount Mapper), I get some weird echo effect, completely unusable.
You've got a feed-back loop going on.
Make sure that "software playthrough" is disabled in "Edit > Preferences > Audio I/O". Set Audacity recording input to "MME: Realtek HD Audio Input" (on the same Preferences page), then over to the Realtek GUI (the mixer/control panel thing). When using the loop-back connector, the Realtek GUI should have only the "Line input" selected.
Before you change anything though, let's go back to the beginning. (please read this entire post as there are several possibilities as to what is going on)
You are wanting to record the audio from a YouTube video that is playing on your computer.
Without the loop-back connector, you can hear the video from your headphones/speakers.
With the loop-back connector, the sound is coming out from the soundcard, going into Audacity, then back out of the soundcard again, into Audacity, and round and round, making a weird echo.
One explanation is that you have "software playthrough" enabled (Audacity, through software, "echos" the input to the output.
The second explanation is that you have "software playthrough" disabled, but the Realtek driver is routing the line input to the line output. To check if this is the case, plug your loopback connector into the Line input only. Open Audacity and click on the recording meter. Now touch the tip of the free end of the loop-back connector and you should see the input meter in Audacity flicker (picking up mains hum) as you touch the tip of the plug. If you turn on your speakers (with them connected to the soundcard output, do you hear the hum? If you do, then the input is clearly being echoed to the output.
You have checked that "software playthrough" is disabled, so you know that it is not Audacity that is sending the signal back out. Go to the Realtek GUI and look at the "playback" page and mute the Line input for playback. (If your Realtek mixer looks like this http://img141.imageshack.us/img141/6280 ... xer0wi.jpg then note the arrows on the right hand side that allow you to scroll left and right to see the other outputs - alternatively, it may be on the Audio I/O page of the Realtek GUI). You should still see the recording meter in Audacity flicker when you touch the jack, but not hear it. Your loopback connector should now work.
paulkinzelman wrote:But when I record with Audacity, when I have it set to the 2nd input (Realtek) I get garbage when I listen to what Audacity recorded when something is playing.
Is this different to the "echo" that you get when you select "Microsoft Sound Mapper"? More like a reverberant distortion than an echo? It's possible that you have accidentally set things up to record "What U Hear" (Stereo Mix) - which is what you wanted in the first place. With "Stereo Mix" selected as the recording input, the soundcard will record from the signal as it appears at the output jack. In this scenario, you will be recording both the Line input, and the direct output from the video at the same time (also if the output (playback) from the Line in is not muted (as above), then you will be recording that as well). The result will be a mess. The solution, if this is the case, is just to remove the loop-back connector.
paulkinzelman
Post by paulkinzelman » Fri Apr 18, 2008 7:56 pm
Duh! I knew that. Happened to me before awhile ago.
Yes, turning off the pass through works, so at least I have a kludge to make it work.
In parallel, I'm buying a PCI sound card on ebay, will try that for the long term solution.
Thanks!
paulkinzelman
Post by paulkinzelman » Sun Apr 27, 2008 3:46 am
I installed a $10 sound card I picked up on ebay and it works great!
Thanks!
