Audacity cannot record on other computer...
GruntOfAction
Post by GruntOfAction » Mon Aug 09, 2010 11:02 pm
I'm not sure why, but on my current computer I can select a multitude of audio imput devices. (Microphone, Line In, Phone Line, Stereo and Mono) But for some reason, on a "better" computer, I cannot even select the recording imput device.
Here are the specs of the one I can use them on: http://h10025.www1.hp.com/ewfrf/wc/docu ... =c00088950
And here are the specs of the one I cannot: http://h10025.www1.hp.com/ewfrf/wc/docu ... ct=3245027
Can anyone here explain why on the newer computer, it cannot record?
Re: Audacity cannot record on other computer...
Post by kozikowski » Mon Aug 09, 2010 11:16 pm
Are you doing this in the Windows Control Panel, or the Audacity Input Panel? In Vista and Win7, you need to do everything in Windows.
Sometimes you need to restart Audacity even after you do get everything selected correctly.
GruntOfAction
Post by GruntOfAction » Mon Aug 09, 2010 11:22 pm
kozikowski wrote:Are you doing this in the Windows Control Panel, or the Audacity Input Panel? In Vista and Win7, you need to do everything in Windows.
This is in the Audacity panel. And it's a Windows XP computer also, both of them are.
Post by kozikowski » Mon Aug 09, 2010 11:28 pm
Your example has Vista running on the second computer.
You still need to be in the Windows Control Panel. Audacity is a complete slave to whatever the computer is doing. Some machines couple the two services so Audacity controls the Windows services. Some don't.
GruntOfAction
Post by GruntOfAction » Mon Aug 09, 2010 11:56 pm
kozikowski wrote:Your example has Vista running on the second computer.
My mistake, the one at my house is Windows XP.
So would it be WCP/Sounds and Audio Devices or Realtek?
Post by kozikowski » Tue Aug 10, 2010 12:21 am
Since I'm one of the Mac elves, I'm going to take one giant step backwards and let the Windows elves pick this up.
GruntOfAction
Post by GruntOfAction » Tue Aug 10, 2010 12:39 am
kozikowski wrote:Since I'm one of the Mac elves, I'm going to take one giant step backwards and let the Windows elves pick this up.
Lets hope someone with more Windows XP experience is online then. :P
Post by kozikowski » Tue Aug 10, 2010 12:57 am
I do use Windows 2000 and Windows 98 which doesn't do you any good at all.
GruntOfAction
Post by GruntOfAction » Tue Aug 10, 2010 1:33 am
kozikowski wrote:I do use Windows 2000 and Windows 98 which doesn't do you any good at all.
Yep, I'm afraid those are older than the computer I'm using...lol.
waxcylinder
Post by waxcylinder » Tue Aug 10, 2010 9:00 am
By "better" computer I assume you mean a more modern one, right? If so this may be the cause of your problem. The choices that you get in that input selector dropdown are entirely dependent on your particular computer, its operating system, the soundcard and its associated drivers.
See this from the Wiki: http://wiki.audacityteam.org/index.php? ... bar_Issues
So it is not uncommon that two particular PCs that you run will offer entirely different options in those boxes.
Are you using XP on both PCs? Are the soundcards in those PCs the same or different? If they are the same, do you have the same versions of the drivers for the soundcards loaded on both PCs?
