temparytopwindow??
corpitos2013
temparytopwindow??
Post by corpitos2013 » Mon Aug 09, 2010 4:46 pm
hey umm my audacity isnt working anymore it says temparytopwindow and aplication error wont let me get on it whats wrong???
Re: temparytopwindow??
Post by Gale Andrews » Mon Aug 09, 2010 9:33 pm
corpitos2013 wrote:hey umm my audacity isnt working anymore it says temparytopwindow and aplication error wont let me get on it whats wrong???
This usually occurs because you have installed a VST instrument plug-in on your system (like those that come with Fruity Loops), but Audacity doesn't support VST instruments and the 1.2 version of Audacity isn't always able to ignore them properly. If this is the reason, either remove the VST Enabler from the Audacity installation folder, or move the VST instruments to a folder Audacity doesn't look in. See here for the system folders Audacity loads VST plug-ins from.
Alternatively just use Audacity Beta 1.3.12 which should ignore the VST instruments properly.
If this doesn't help please post a screenshot of the error you see (ALT + PrtScr then paste into Paint and save).
