play recordings in programs like ventrilo
ivan
Post by ivan » Fri Jul 30, 2010 3:59 pm
as the headline says, i was wondering if there is any way that i can play the recording in a program like teamspeak or ventrilo
and i was also wondering (just since i first got this thing up) if you guys know anywhere they make custom voice changers, cause i really want one :D
thanks
ivan
Re: play recordings in programs like ventrilo
Post by steve » Fri Jul 30, 2010 5:07 pm
Are you able to play the audio output of other programs (such as Windows Media Player?
If you are, then Export your Audacity Project as a WAV or MP3 file and play that file.
Audacity does not do real time processing. It is designed to record/import, then edit/process then export the finished work as a file.
