mad electric noise at 30 seconds
stueychef
Post by stueychef » Thu Jul 29, 2010 2:28 am
Hello All,
New to Audacity and overall I love it.
Having a problem, though, while recording from either my pedal board (guitar) or Kawai Digital Piano.
Every time I try to record the piano, it makes it to anywhere between 28-30 seconds, and then it's just terrible electric noise...high decibel stuff.
I am monitoring the CPU usage and it doesn't go over 11% and I am running XP on a Dell Latitude D830.
Help, please!
Re: mad electric noise at 30 seconds
Post by kozikowski » Thu Jul 29, 2010 2:49 am
That is a laptop. Without going into the technical specifications, the computer probably does not have a high volume, Stereo Line-In connection on its side. It's much more likely to have a mono Mic-In connection (same type of plug) which will overload in the presence of a hot, stereo signal.
It's possible you have a "real" stereo Line-In and you should look for that in the instructions. If not, you may need one of the high volume, stereo, USB adapters like the UCA 200.
http://forum.audacityteam.org/viewtopic.php?f=27&t=9477
stueychef
Post by stueychef » Thu Jul 29, 2010 11:05 am
Thanks. In looking at the UCA 202 or 222, are there cables to connect from a 1/4" audio cable into the UCA or do I also need a mixer?
I am trying to do this on the cheap, as we are single-income with four kids, and my wife is getting concerned with the new interest in music from a financial standpoint :)
I appreciate your advice.
Cheers
Post by steve » Thu Jul 29, 2010 2:06 pm
A mixer would be nice :) but to avoid the expense you should be able to get a reasonable recording level from your keyboard by plugging it directly into the UCA 202 with a suitable audio cable. Check to see if your digital piano has outputs marked "Line out", Aux", "Stereo Out" or something similar - if it does, then those are the best outputs to use.
stueychef
Post by stueychef » Thu Jul 29, 2010 6:28 pm
Thanks to all. I will pick up a USB controller. And yes, the piano has line in/out and AUX and quite a bit more on the back, so I'll be good to go.
Cheers
Post by kozikowski » Thu Jul 29, 2010 11:31 pm
You are not forbidden from using the headphone connection if you can't do it any other way. That's how I did both piano2.wav and organfinale.wav from here...
http://www.kozco.com/tech/soundtests.html
