Just installed Audacity and cannot open its Content File
Axis Sallyboy X.
Post by Axis Sallyboy X. » Sun Jul 11, 2010 8:20 pm
I just installed Audacity 1.2.x onto my PC. As soon as I try to start it, I get a prompt telling me it should be located at a certain ".NKS" file. In this case, on my PC, it states that this particular ".NKS" file is "[not set]Kompakt_Sony_ACID_1.nks". For some reason, Audacity won't load up through that or any other directory for that matter. Does anyone have any suggestions??
Last edited by Axis Sallyboy X. on Fri Apr 24, 2015 3:26 pm, edited 2 times in total.
Reason: grammar correction in post title
Re: Just installed Audacity and cannot open its Content File
Post by Gale Andrews » Mon Jul 12, 2010 12:45 am
Axis Sallyboy X. wrote:I just installed Audacity 1.2.x onto my PC. As soon as I try to start it, I get a prompt telling me it should be located at a certain ".NKS" file. In this case, on my PC, it states that this particular ".NKS" file is "[not set]Kompakt_Sony_ACID_1.nks". For some reason, Audacity won't load up through that or any other directory for that matter. Does anyone have any suggestions??
Have you got Sony Acid Pro which comes with the Kompakt VST Instrument, and have you installed the Audacity VST Enabler? If so, Audacity can't work with VST instruments yet. Delete the VST Enabler so that Audacity can't find Kompakt, or use 1.3.12 Beta which should ignore Kompakt while still letting you use VST effects. See this Wiki page to read about Audacity's VST support.
Axis Sallyboy X.
Post by Axis Sallyboy X. » Mon Jul 12, 2010 1:21 am
awesome. will do :D
