retrieving audio
garyjamesmedia
retrieving audio
Post by garyjamesmedia » Thu Jul 08, 2010 3:30 pm
> I have a problem trying to retrieve audio that was saved after being
> edited, but on reopening the wave is just one straight line.
> Also, after recording audio, I clicked on the small x in the top left
> hand corner by mistake, and the section disappeared.
how do i recover all of the above?
> Please can you help.
Re: retrieving audio
Post by steve » Thu Jul 08, 2010 5:19 pm
It may be too late to rescue your current projects.
While a project is open, you can undo actions by pressing Ctrl+Z (or select "Undo" from the Edit menu)
This article may give some clues as to what went wrong in the other project, or at least help you to avoid the problem from re-occuring: http://wiki.audacityteam.org/index.php? ... ement_Tips
