Lost my saved files and do not know how to retrieve them aga
Waleed Fadoo
Post by Waleed Fadoo » Sun Jul 04, 2010 10:49 am
Hi All,
I have lost my flash drive (portable drive) that contained my Audacity 1.2.6. files. Unfortunately, I have no backup of those files. Really I want them badly for my work. I am wondering if there is a way that allows me to retrieve or restore those files. For your information, I am using Windows 7 and I have recorded many files after them.
Kindly, help me to sole my problem
whomper
Probationer
Re: Lost my saved files and do not know how to retrieve them
Post by whomper » Sun Jul 04, 2010 1:08 pm
you really need to find your flash drive
search your pc for files like *.au or *.aup
if you find any then you might have some backups saved on the hd
Post by steve » Sun Jul 04, 2010 3:12 pm
Waleed Fadoo wrote:I am wondering if there is a way that allows me to retrieve or restore those files.
Retrieve or restore them from where?
Did you create the projects on your computer hard drive, then delete the projects after copying them to your flash drive? If so, have a look in the Recycle Bin and see if they are still there.
BTW, the recommended version of Audacity for Windows 7 is version 1.3.12, which you can download from here: http://audacityteam.org/download/beta_windows
Trebor
Post by Trebor » Sun Jul 04, 2010 4:27 pm
There is a free Windows programme called Recuva (Recover geddit) which can recover deleted files on your computer's hard drive, provided they have not been overwritten.
[it also works on MP3 players, flash (thumb) drives, SD memory cards]
whomper
Probationer
Post by whomper » Sun Jul 04, 2010 5:06 pm
only if you *have* the flash drive 8-)
now we need an ap to find lost ones
Post by steve » Sun Jul 04, 2010 6:04 pm
whomper wrote:only if you *have* the flash drive
Or if the project was originally on a hard drive, or if Waleed means that he has lost the data from his flash drive rather than loosing the drive itself.
I doubt that someone would write in to the forum expecting help in finding an item that they had physically lost, so perhaps it would be better to wait for some clarification about the matter.
Waleed Fadoo
Post by Waleed Fadoo » Fri Jul 09, 2010 8:17 am
Dear friends, Whomper, Stevethefiddle, Trebor,
I appreciate your comments and willingness to help. It seems now I have no hope to find my thumb drive, at all. I just wonna say that after recording I saved on my computer then I transferred the files to the thumb drive. Well, I couldn’t find them anywhere in my computer.
Again I am so thankful for your help
