Starting Audacity
choirlady
Starting Audacity
Post by choirlady » Thu Jul 01, 2010 12:57 pm
When I try to start Audacity, my computer says there is already an Audacity running. It doesn't show up in the task manager. I tried deleting Audacity and reinstalling it, but that didn't help. Any suggestions
whomper
Probationer
Re: Starting Audacity
Post by whomper » Thu Jul 01, 2010 4:30 pm
that happens with win on many programs at times
billygs boyz prefer to get it out fast instead of right
so we have to live with these rough edges
possible fix
do ctrl alt delete in order to
bring up task manager
then go to the applications tab
and delete the currently "running" audacity
then try again
sometimes these ghost programs do not show up
then you have to reboot to clear them
adobe is famous for that
some other programs starts adobe to shwo a pdf file
not in the task manager but it is still running
only solution is a reboot
Post by steve » Thu Jul 01, 2010 4:49 pm
choirlady wrote:When I try to start Audacity, my computer says there is already an Audacity running. It doesn't show up in the task manager. I tried deleting Audacity and reinstalling it, but that didn't help. Any suggestions
The problem is most likely due to an error in the Audacity Preferences, in which case you need to reset the Audacity Preferences.
Use the "safe solution" as described here: http://wiki.audacityteam.org/wiki/Audac ... o_defaults
waxcylinder
Post by waxcylinder » Thu Jul 01, 2010 4:51 pm
You will need to reset your Audacity preferences.
See: http://wiki.audacityteam.org/wiki/Audacity_Preferences
