Recording Issue with Mic
munkifisht
Post by munkifisht » Sun Jun 13, 2010 1:51 am
I am trying to get Audacity to record from a mic, well in truth from two mics. I am running windows 7, I have V1.2.6 and the Beta 1.3.12. I have selected Microphone in preferences, stereo, the quality as 44100 Hz & 32-bit float Default Sample Format. When I hit the record button I get the error
"Error while opening sound device. Please check the input device settings and the project sample rate."
My soundcard is a Realtek card inbuilt on my Asus P5Q Pro motherboard, and has multiple inputs. Any ideas?
Re: Recording Issue with Mic
Post by kozikowski » Sun Jun 13, 2010 2:37 am
You glanced briefly at "recording two mics." How are you doing that? Most computers -- say all -- won't let you do that.
You can start with setting Audacity preferences for 44100, 16-bit, mono. Restart Audacity to make sure the settings stick. Then dig in the Windows Control Panels to select the microphone -- the one single microphone. See if that works.
Mic-In on a Windows machine is mono. It uses a stereo plug, but it's not stereo sound. It uses one of the connections to apply battery to run the microphone -- second illustration:
http://www.kozco.com/tech/audioconnecto ... ctors.html
whomper
Probationer
Post by whomper » Sun Jun 13, 2010 1:08 pm
munkifisht wrote:I am trying to get Audacity to record from a mic, well in truth from two mics. ...
Realtek has TWO microphone inputs?
On win7 ??????
Tell us more.
Which version of realtek?
Which pc?
I suspect you only have ONE MIKE input.
You have to put mikes into mike inputs.
Put higher level line signals into the line inputs.
you need a mixer or an external interface to use two mikes.
Maybe, *IF* your soundcard has a stereo mike input , which would be unusual , you could get adapater cables to run two mikes into a single mike *stereo* input -- *IF* it were truly a stereo input and not merge the mikes into a single signal.
munkifisht
Post by munkifisht » Sun Jun 13, 2010 1:52 pm
Yea, there are front connections and rear connections. I don't know how it's done, virtualised I assume. The board it self is inbuilt to the motherboard, but I believe the model number is ALC1200, although, whether you can buy it as separate hardware, I'm not sure. I say virtualised as it's all done through the audio management software. With that I can change an input connection to an output and I can also decide whether I want the connections on the front panel and back panel to play two different audio streams, like having two soundcards (great for DJing) or/and I want to separate all input jacks as independent devices or not. It's a cracking bit of kit really
munkifisht
Post by munkifisht » Sun Jun 13, 2010 2:02 pm
I have found that if I select "Separate all input jacks as independent devices" I can record, however this leaves me with the problem that I kinda need to record from two sources at once.
Post by kozikowski » Sun Jun 13, 2010 2:52 pm
Which Audacity wont do. Audacity will only record from one "device" or channel at a time.
Post by kozikowski » Sun Jun 13, 2010 2:55 pm
There are ways to force certain computers to accept two inputs at the same time, but they're not generally good for production. They're digital celebrities and they generally stop at two.
You need a mixer.
