Possible to use Audacity to record from 2 inputs?
Reddog DL
Post by Reddog DL » Wed Jun 09, 2010 11:48 pm
Basically, I would like to record a conversation over Skype. I would like the other users in the call to be recorded on one Audacity, while recording myself talking at the same time. All I have seen so far is a way to get one input recording at a time.
Now before when my Mac was working, I had Soundflower route them from Skype, to my headset and Garageband. I then recorded myself using Audacity.... this all being for our podcast.
Now that the Mac is down for awhile, I need to know how to duplicate that process on Windows Vista.
Thank you for your help,
Reddog
Re: Possible to use Audacity to record from 2 inputs?
Post by steve » Thu Jun 10, 2010 12:10 am
As with Mac's the Windows sound system won't allow you to record both sides of a Skype conversation, bus as on a Mac, there is software that can get you round the problem. Pamela is probably the best known - you may also be able to do it using Total Recorder or Virtual Audio Cable. There are several other programs if you look on Google - definitely go for one that you can try before you buy to be sure that it works on your system.
Reddog DL
Post by Reddog DL » Thu Jun 10, 2010 12:13 am
Thanks for the quick reply, I will try it out for sure.
Post by kozikowski » Thu Jun 10, 2010 1:23 am
Pamela is designed to do this, but only the top two versions, Professional and Business, split the conversations for post production. The bottom two versions are intentionally crippled.
I don't know of a free way to do this. Total recorder is money-based software.
