no sound whilst recording
kevin83
Post by kevin83 » Sun Jun 06, 2010 1:39 pm
i cant hear as im recording but when i play it back its there, what the shiz can anyone help im probably being well diumb cheers
Re: no sound whilst recording
Post by Gale Andrews » Sun Jun 06, 2010 2:10 pm
kevin83 wrote:i cant hear as im recording but when i play it back its there, what the shiz can anyone help im probably being well diumb cheers
What are you trying to record? Try enabling "software playthrough" at Edit > Preferences: Audio I/O if you are recording tapes or records. If you are recording from microphone, go to the playback side of "Sounds" or similar in the Windows Control Panel and unmute the microphone. It may not work, but there should be no delay if it does.
