hi,
I am currently making potter puppet pals animations on windows movie maker and am trying to use audacity for the sound. As you probably know audacity isn't compatable with it so i was just wondering weather there was a way to put audacity recordings on to it or if not if there was something else i could use instead.
from thehalfbloodgreek
p.s. i have vista if that might help.
audacity and windows movie maker
thehalfbloodgreek
Re: audacity and windows movie maker
Audacity is compatible with Windows Movie Maker, in so far as the latter will import several audio file formats including WAV and MP3 - which Audacity will also happily work with. I've used Audacity several times to edit a soundtrack destined for a Movie Maker project.
thehalfbloodgreek
THANK YOU
