No recording waves
Jeanraw
No recording waves
Post by Jeanraw » Fri Feb 22, 2008 4:12 pm
I have just received a replacement turntable and when I use it there are no recording waves. I have changed Sound to line in as instructed in book but it did not help. Also the usb cable keeps coming up as unrecognised by Windows. I have tried another cable but still no joy. Can anyone help please
waxcylinder
Re: No recording waves
Post by waxcylinder » Fri Feb 22, 2008 5:04 pm
Sounds as though you may have a duff USB line/plug or even a fault on the soundacrd on the TT. But it may just be a bad USB port - try plugging to another USB port - and don't use an ISB hub.
BTW it would help if you told us which make and model of USB TT you have.
Jeanraw
Post by Jeanraw » Sat Feb 23, 2008 5:38 pm
I have tried other ports with no joy. All the ports work with my mp3 or camera, its just the turntable it wont talk to. I know the ports are ok. And everything worked fine with my previous turntable. It was only sent back because the arm did not reach the last track on lp. It is a Zennox turntable - very basic
waxcylinder
Post by waxcylinder » Sat Feb 23, 2008 6:11 pm
Probably the souncard in the TT or the USB plug itself - another one to return methinks......
