Cannot uninstall!
Cannot uninstall!
Help please anyone! I cannot uninstall Audacity via add/remove progs. Its v1.2.4 .When I click on it remove, i get a windo saying the file doenst exist, yet it takes up 5.84mb. Any ideas pls? (XP)
Re: Cannot uninstall!
A - Install it again to the same directory (this will overwrite the previous installation) then try uninstalling.
or
B - Delete the Audacity temporary directory and the main Audacity directory (this will leave your preferences in the registry, which you can either remove manually, or just leave them).
If you need more detail, please post again in this thread.
or
