Ringtone file size too large!!??!?
hockeyplayer2004
Post by hockeyplayer2004 » Tue Feb 19, 2008 5:45 pm
ok so normally when i download ringtones they are downloaded in a .dm format at 15 seconds long... my phone will allow mp3 format or wav format for ringtones but when i cut out my 15 seconds or even 10 seconds of ringtone, my phone says the file size is too large... is there a way i can make the file size not so large but yet still be 15 seconds???? :?: :!: :?: :!:
:D
waxcylinder
Re: Ringtone file size too large!!??!?
Post by waxcylinder » Tue Feb 19, 2008 7:20 pm
Yes, you can try reducing the exported bitrate of the MP3 - Audacity default is 128 (which is the minimum for proper music). For a ringtone you should be ok going a bit lower.
Go to Edit > Preferences > File Formats - you should see a drop-down which will let you reset the MP3 bitrate.
hockeyplayer2004
Post by hockeyplayer2004 » Tue Feb 19, 2008 10:07 pm
i see where its set at 128 bit rate but it doenst let me click it and have the drop down... i dunno why...
waxcylinder
Post by waxcylinder » Wed Feb 20, 2008 9:35 am
In order to re-set the rate in the dropdown (and indeed to export MP3) you need to have LAME installed properly and have Audacity pointing at it.
