Exception processing message error
mattmunin
Post by mattmunin » Sun Feb 17, 2008 5:01 am
Hello,
I was mixing the tracks of my band's song the other day, and everything went completely smooth. I finished the mix, and saved my aup file. However, today when i went to export the song, when i tried to do play the song, or export it, i got a splash screen message pop up....
Exception Processing Message c00000013 parameters xxxxxxxxxxxxxxxxxx (the x's are a bunch of hex values i didn't feel like writing down)
The splash message has three buttons, cancel, try again, and continue. each one does causes an identical message to pop up.
has this error happened to anyone before? and if so, do you know how to fix it?
thanks,
Matt
comcon
Re: Exception processing message error
Post by comcon » Sun Feb 17, 2008 8:19 am
"Exception Processing Message c00000013" is strongly associated with Malware.
You're likely infected.
Goodluck
