Input volume only in left speaker
igotseoul
Post by igotseoul » Tue May 25, 2010 5:40 am
First off I apologize if this has already been asked.
Anyways, I just started using Audacity. When I record audio through Wave Out Mix, there is input volume only in the left speaker when I check the meter. First, is this normal? And if not, then how do I fix it.
waxcylinder
Re: Input volume only in left speaker
Post by waxcylinder » Tue May 25, 2010 8:36 am
Have you set your Audacity to record in stereo 2-channel - by default 1.2.x is set to mono.
Just go to Edit > Preferences and select the Audio I/O tab. In the box markked Recording you will see where you can set Channels.
