Hi.
I d/l the user manual unzipped it, the instructions said to click on the "index.htm" file to open. Out of all the icons on the page, even checking the two folder icons there isn't any such file. What did I do wrong?
I want to print the whole user manual out. Please if anyone knows how let me know too!!
Thanks, bikerart
Downloading the User Manual
- Quality Assurance
Re: Downloading the User Manual
bikerart wrote:
"I d/l the user manual unzipped it, the instructions said to click on the "index.htm" file to open. Out of all the icons on the page, even checking the two folder icons there isn't any such file. What did I do wrong? "
Are you downloading:
http://audacityteam.org/audacity-manual-1.2.zip
as instructed at:
http://audacityteam.org/help/documentation
If so, you need to click on index.html as the documentation page says. That page is there - I just checked.
bikerart wrote: "I want to print the whole user manual out"
Printing each html page is a bit of a chore. It would be better to download the manual in PDF:
http://www.gaclrecords.org.uk/audacity-manual-1.2.pdf
then you can print it at one go. To read PDFs you need Adobe's reader:
http://www.adobe.com/products/acrobat/readstep2.html
Or if you can manage with just the reference (excluding the tutorials), go here:
http://audacityteam.org/onlinehelp-1.2/reference.html
and use the Print function of your web browser to print the reference out (which is there complete on one page).
as instructed at:
Thank you. The PDF file is exactly what I was looking for. Now I can print that. That file needs to be the the Audacity download page.
Thanks again.
Art
BTW, the links were broken if you clicked on the opened page in the Index.htm file.
Thanks again.
Art
Hi All, I've just tried the links that Gale stated in his mail for downloading the Audicity Manuals and it doesnt seem to work. Am I doing something wrong or is the links down please?
Any ideas as to how I download the manual?
DaveP
DaveP
- Quality Assurance
The links are all fine as I write. Please just try again.
Just tried http://www.gaclrecords.org.uk/audacity-manual-1.2.pdf and get the message it cannot be found??
DaveP
DaveP
Hi Gale and All, I've managed to access the pdf files now thank you for your help.
DaveP
DaveP
