failure exporting mp3, only 26bytes long
bsrega
Post by bsrega » Wed Feb 13, 2008 12:23 pm
depending of the source (always *.mp3), if I export a part of it as an *.mp3, I only get a very small (26 bytes) file.
Playback & editing of the source-file works, but not exporting..
Reinstalled the newest lame.dll, but no luck!
Any ideas?
comcon
Re: failure exporting mp3, only 26bytes long
Post by comcon » Wed Feb 13, 2008 2:29 pm
Are you sure you have the part of the mp3 you want to export, selected correctly?
Post by steve » Wed Feb 13, 2008 6:38 pm
Does it work if you export part of it as .wav?
bsrega
Post by bsrega » Fri Feb 15, 2008 9:12 am
stevethefiddle wrote:Does it work if you export part of it as .wav?
Yes, this works, only exporting to mp3 somtimes doesn't..
bsrega
Post by bsrega » Fri Feb 15, 2008 9:14 am
comcon wrote:Are you sure you have the part of the mp3 you want to export, selected correctly?
yes, I sure do this it right..
Post by steve » Sat Feb 16, 2008 5:26 am
bsrega wrote: Yes, this works, only exporting to mp3 somtimes doesn't..
What do you mean - " somtimes doesn't.."
bsrega
Post by bsrega » Sun Feb 17, 2008 6:52 pm
bsrega
Post by bsrega » Sun Feb 17, 2008 6:53 pm
Like I said, it's only 26bytes long, not usefull..
