Technological Troubles
Othello
Post by Othello » Tue Feb 12, 2008 8:09 pm
Ok so the other day I had the bright idea of hooking my PA up to my computer using a 1/4th female to 1/8th male converter to record some of my bands jams on to the ol' computer. Well, it went great the first day, everything was fine. The next day I wake up and start to record a guitar track with my friend and noticed that it is clipping everything at .5 instead of 1. Why is this? Can I fix it? Did I just screw up my sound card?
Re: Technological Troubles
Post by steve » Wed Feb 13, 2008 7:12 pm
You need to check the entire signal chain - from microphone through to the recording software. The first thing to identify is where in the chain the signal is clipping. My guess would be that you could be driving the sound card input too hard.
Othello
Post by Othello » Fri Feb 15, 2008 1:38 am
I've decided to buy a USB audio interface instead of using my line in and all that stuff.
