I need some help please:
I have Windows seven and I am using the Audacity Beta.
and every time I try to play anything or record with an exisiting track I get:
Error while opening sound device. Please check the output device settings and the project sample rate
I tried changing the output device setings and that didn't work.
I don't know where the project sample rate is-
does anyone have any suggestions on how to solve this problem?
Issue with playback
autumnRose
Re: Issue with playback
For Windows 7 you need to use Audacity 1.3.12
autumnRose
That's what I'm using now.stevethefiddle wrote:For Windows 7 you need to use Audacity 1.3.12
In that case, let's keep it in the Audacity 1.3.x part of the forum
http://forum.audacityteam.org/viewtopic ... 16&t=30732
