So the problem is that the song doesn't open in Audacity.
The reason i want to edit it, because the sound kind of envelopes up and down when playing it in vlc media player, even though it isnt supposed to.
It plays like normal in foobar 2000, so I'm wondering what's wrong.
Audio Identifier 0.7.1 Says that the encoder is Vorbis AO;aoTuV [20061024] (Based on Xiph.org's libVorbis)
Audacity can't open an .ogg file
- Quality Assurance
Re: Audacity can't open an .ogg file
What is the error given? What is the bit rate of the file?Zeroism wrote:So the problem is that the song doesn't open in Audacity.
As I understand it, Aoyumi's Tuned Vorbis (aoTuV), although widely recommended, isn't the official release of Xiph.org. It is an encoder optimised for higher performance at very low bit rates. Lower bit rates reduce the quality of the file.
Have you tried opening the file in Audacity Beta ? The Beta also supports import/export via the optional FFmpeg library. Sometimes that library can import a file when the inbuilt ogg importer can't.
If you want us to look at the file, then if it's up to 1 MB in size you can upload the file here ("Upload attachment" underneath the Preview/Post Message buttons). Otherwise please upload it to a free file transfer service such as:
http://www.yousendit.com/
http://www.sendspace.com/
and let us know the web address where we can download it.
It succeed to open it with the beta version.
Thanks!
Thanks!
