Putting in breaks
grouch
Putting in breaks
Post by grouch » Fri May 14, 2010 2:37 pm
Sorry but not very technical and need help.
Have been recording stories and want to put in breaks every 10 minutes so when playing via USB I can stop and then find the place stopped on another occasion. Is this possible.
waxcylinder
Re: Putting in breaks
Post by waxcylinder » Fri May 14, 2010 2:45 pm
Create a label at your break point - place your cursor and use CTRL+B.
When playing in Audacity you can TAB from lable to label, provided focus is on the label and label track.
If you want to burn a CD with these beraks as CD tracks - just use Export Multiple to create a set of 44.1kHz 16-bit PCM stereo WAV files and use a CD burner to make a CD from the WAVs (note: you may want to use "gapless burning").
Post by steve » Sat May 15, 2010 1:28 pm
Labels can be added every 10 minutes using "Regular Interval Labels" from the Analyze menu.
grouch
Post by grouch » Sun May 16, 2010 8:58 am
Unfortunately when I select the Analyze Menu I do not have the choice of interval labels.
waxcylinder
Post by waxcylinder » Sun May 16, 2010 9:03 am
grouch wrote:Unfortunately when I select the Analyze Menu I do not have the choice of interval labels.
1.3.x had this added as a new feature - so to use regular interval labels you will need to upgrade to 1.3. You will benefit from this greatly as 1.3 has many improvements of the now ancient 1.2.
You can get 1.3 from here: http://audacityteam.org/download/
grouch
Post by grouch » Sun May 16, 2010 2:44 pm
Thanks. I am trying to put breaks in a 45 minute recording. I wish to divide this into 2. I find it difficult to understand the first break and then the intervals thereafter. Sorry but I am totally useless in tis sort of thing.
Post by steve » Sun May 16, 2010 4:47 pm
If you only want to split into 2 parts, the easiest way is to zoom out so that you can see the entire waveform, then select the first half by clicking and dragging your mouse from the middle of the track to the beginning. You can then use "Export Selected" to export that half. To export the other half, press the Del key (which will delete the selected section) and then use "Export" in the normal way.
