Window Vista Problems
I have Vista Home and I had Audacity and it did not when I wanted to get audio from the hard drive so I installed Audacity Beta think that would fix my problem. This is the problem I can not get Audacity to record from the hard drive and I did install Realtek as well. but it dose not let me change the input device.
Re: Window Vista Problems
did you tell realtek to show all the devices instead of hiding some
did you then enable the input device you want to use?
